We'll need more information to be able to help. Can you post again including anything that may have happened to the phone (drops, water, software or app updates, even silly stuff like running the battery flat - anything at all might be relevant). Also what software version you are running, whether the phone is rooted or not, and if the phone is network branded what network (in case you need to reload software).
You could try pulling the battery out for a couple of minutes. If you are rooted I'd suggest clearing cache and dalvik cache (you won't be able to do this if not rooted). These are just generic suggestions though, not things I have reason to believe will fix this particular problem.
If none of that works I'd suggest backing up all important data, because if you need to do a factory reset or have the hardware repaired you will lose the data on the phone either way.
