zuben el genub
Extreme Android User
I've searched and got quite a bit on the privacy end.
My Moto has seemed to start opening programs on the list that only runs in memory - the ones you are not supposed to use task killers on. If I leave them for android, I find them open after I get the phone out of the leather holster I use. I've found the camera on and the phone has got hot.
They used to shut off, and stay off, but Moto just put out a security update and leaving apps for android to take care of no longer seems to work. I can task kill from the screen and will have to.
I'd like a suggestion for some kind of program to run as a memory aid.
Can a lock screen shut off any apps until unlocked? Would be the simplest way, but have not seen any answers to that question directly when searching.
Unlocked and running 6.0
