Yessir! It is finally here.. As far as I am concerned, this is a must-have widget! Previously known as ScreenModeWidget, I have watched this app blossom
This widget was the first glimpse to me of the awesomeness of ANDROID.
Within the first couple weeks of having my droid, I began getting annoyed with the Lock Screen while I browsing the web (probably sponging up info from this forum). I then thought, " well, I wonder if there is any way to modify this.. Some app that would disable the lock screen." Low and behold, someone else was already tackling this problem! I found ScreenModeWidget suggested somewhere on the net and searched for it in the market.
It wasn't pretty but it did it's job and I loved it. The only problem with it was that the volume and the camera buttons would involuntarily turn the screen on. This almost made it useless. Especially if you wanted to throw your droid in your pocket.
Well it seems like Sam finally figured it all out and has released Screen Mode Widget Lite and Screen Mode Widget Pro. I went straight for PRO to show this dev some love so I'm not sure how different the lite version is (I believe it just has an ad one the setup screen). But I can tell you that the PRO is flawless on my Droid.
It has 3 different modes: Lock Mode operates your phone like normal Unlock Mode allows your screen to come back on without swiping and Screen Stay will keep your screen on continuously. He added protection for the volume and camera buttons (clutch!) and it has a very handy and simple widget to toggle between modes.
Again, to me this is a must have app. It is something I have been looking for since I got my Droid and I am not the only one... I think it took quite some time for the dev to get it right so I would encourage people to donate, it's only like 1 buck! Hope this helps some people
