screen problem (cracked and rainbow colored pixels)
niloroth
So, I dropped my phone a few weeks back which cracked the screen (HTC EVO 4G LTE), and have meant to replace the screen, but it was usable, and i was busy so i never got around to it.
Then yesterday i take it out of my pocket, and it is crazy. (see attached pics) I can only describe it as the individual pixels going all rainbow.
The touchscreen sort of works, in that i can occasionally answer calls by remembering where the answer button should be, but not consistently. I can't seem to get the unlock pin entered correctly, but the alarm went off this morning, and i got it to dismiss after the second attempt. It is ringing fine, and it is getting updates. As you can see from the pics, it sometimes covers the whole screen, and sometimes shows the notification bar perfectly, but the rest is still rainbowed.
So, i figured i would ask around a bit, before i spent the $60 on a new lcd screen and digitizer. Since if it turns out to be more damage than that, i don't want to waste money if i am going to have to buy a new phone.
Hope this was clear enough, if not, ask away and i will try my best to answer.
Thank you
Dude! That sux. Looks like you're gonna have to replace that screen sooner than you planned...
