Help Screen sleep issue on ics?
Ewing33855
My friend and I both have this issue.
The sleep mode under display options does not work. No matter what time I set the sleep option to, the screen does not turn off unless I manually press the power key.
Anyone figure this out?
The only time I run into an issue like yours is when I am connected to the HDMI Station and watching Netflix. Other than that if I set sleep to 15 or 30 seconds or 1 minute its flawless. No idea to correct it yet though.
Got to thinking..stupid question time. Is this happening while the charger is plugged in? If it is go into settings, developer options, and make sure to uncheck where it says screen stays on while charging.
Yep, mine defaulted to same after ICS update. When charging screen always went dim, never off. The switch in developer settings fixed it.
