Screen Time out while using Navigation
paladaxar
It seems like there should be an easy fix (change a setting or something) for this, but I can't seem to find it and it's driving me nuts.
Whenever I use Google Navigation, the screen times out after a minute (just like any other time I'm using my phone). But, doesn't it seem like the screen should not shut off EVER while using Nav? Is anyone else experiencing this?
There are options here:
You can set your 'Screen Timeout' for longer by going to Settings > Sound and Dispaly > Scroll down to Screen Tmeout and change.
You can download an APP called 'Toggle Screen Timeout' free from the market put on your 'Home Screen' then when you want to block 'Screen Timeout' just press this widget first, remembering of course to press it again when finished.
There are also Apps on the Market like 'KeepScreen' which block 'Screen Timeout' when predefined applications are active, also free.
Hope you find what you are looking for :)
Hey thanks Ziani. Those are some great options. Thanks for the quick response.
Fortunately, the problem is gone now. I... (*cough* *sputter*) cycled the power and everything works now. I had tried everything, but in the end, a good ol' "reset the thing" is what did the trick.
I'm not sure what caused the problem in the first place. Perhaps a defunct flashlight app or something.
There's also an app in the Market called "ScreenOn," and it allows you to define a list of programs that the screen will never turn off for. I use it for my ebook reader and Google Maps (when I'm not "navigating" somewhere but just want the Droid to stay on with the map showing).
I was all set to respond to your OP about that not being the case for me - glad it started working correctly for ya. Q: You didn't by chance use an app killer before this started occurring, did you?
How would I set this during phone calls? I couldn't find it in the applications.
Thanks
The reason it does it with calls (non speakerphone) is that it prevents you from doing something to the phone (like pressing the hangup button) when you are on it. AFAIK there is not a way to disable this....
Good find - I found another one but I may give this one a try as well...
