Screenshot problem
DrewP1337
I know i can use the s pen to take a screen shot. But if I try to use the home button and the power button together it wont take a screenshot. I fiddled around in the settings and couldnt find anything that might be off to prevent the screenshot from happening.
IDK I thought the home/power - screenshot was always on. Another option (I believe easier) is to.. under settings; Motions and gestures; Palm swipe to capture - turn on. Then just swipe your hand across the screen to capture screenshot.
I prefer the hand swipe to the button press. I much more successful getting the function to work swiping vs hitting the buttons right.
