Ok, I managed to Root this tablet using this guide on xda, http://forum.xda-developers.com/showthread.php?t=2044496. The issue is when I plug in to a PC, it does not give me my ext sd card as a drive to open. I tried three different cards. So I am stuck at step 4 and 5 for the CWM install. I can take the sd card out and use the reader on the laptop, and transfer that way but, that is time consuming.
Not sure if it related, GScript and Mobileuncle both look for files in the "sdcard" folder. On these devices, mine anyway, the ext sd card folder is "sdcard2". I had to move the files to the internal storage to finish those steps. That is not working for steps 4 and 5.
Has anyone used this guide and successfully completed it with no problems or had a problem like this and fixed it?
Maybe someone can tell me a easier way to install CWM?
The device is a A2107A-H on AT&T.
Thanks in advance.
Thanks in advance.
