has anybody try to do the sd card fix like on kit kat and lollipop so apps can write to it i heard if you format it then windows wont be able to recognize it?
edit Should of said for the marshmellow 6.0 im on metro and did the tmobile flashing and stuff like that now im rooted and was wondering if anyone has tried an sd fix for it like previous versions
