I have a sd card with some movies in itunes format on it is there an app or something i could do that means i could play them (i have gone onto my files and i does not work
Thankyou
(Asus eee pad)
If by "iTunes format" you mean files with an extension of "mp4", you should be able to play those with the stock media player. If they have some kind of drm associated then I have no idea.
