Help SD Card for Note 4
usmann090
Hy guys
I wanna buy sd card for my note 4.
Kindly guide me which sd card I should buy?
I wanna ask about class and company.
I don't know which one is better Samsung, Kingston , Sony, Sandisk etc.
I am gonna but 64GB.
Thank you
Hi,
This has been answered a number of times before so you can take a look back in the forum history to get a complete list of recommendations, but I use SanDisk cards and have never had a problem with them. I currently have a 128Gb XC1 card (class 10) which I use to store videos and music.
Regards,
Eric.
Hi,
Regards,
Eric.
Thank you
I used a Sandisk 128GB in my Note 4 with no issue. Use a reputable dealer to make sure you don't get a counterfeit card. If the price is too good to be true, it IS!
Yeah.
Thank you.
But SanDisk cards are bit expensive when compared to samsung
I'm using Samsung Evo 64gb, can't complain... awesome card. Found it on Amazon for about $24, but paid $29 in my local Walmart store just because I can see it and get it right away, and it's original Samsung card. Also, this is one of the best, if not the best one (not only in my opinion) MicroSD cards available. Don't waist your money on a supper-pupper cards with speeds over 90mb/s as your device will only read and write with speeds it capable of, and you need this card not for your PC where you can get the full potential of it.
