I made the switch from iPhone to Android and have searched the web but can't find an answer to this:
I have a Samsung Galaxy Note 2 to which I added, and formatted, a 32gb SD memory chip. When I plug the phone into my Windows 8 machine, the SD card appears as the K: drive.
I copied 2,000 songs to the card. I unplugged the phone, then plugged it back in to the computer. The songs were still there on K: and I tried playing a couple to make sure they transferred correctly.
However, neither the "Play Music" or "Music Player" app can see these songs.
I purchased an app called "Synctunes" to sync itunes playlists and try it that way, but it put all the songs into the (small) 16 gb main memory, which is not what I want, so I had to deleete those songs
I changed "On device" to "all music" and still nothing.
There doesn't appear to be anything at all on the SD card. Even photos are stored in main memory.
How do I make the music player and other apps use the SD card? Do I have to create a special subdirectory for my music? Is there anything I can use that was as easy as just clicking "Sync" in iTunes? I'm willing to buy a third party app but before I do I want to be SURE it can read the SD card.
Thanks for helping a newb.
