Have you tried loading the card in a computer? You can most likely extract the images that way, or at the very least rename the folder to the proper title even if you're not able to do so using a file manager on your device.
Thanks for the help! i plugged it in as you said and still nothing, but i then ran the Recover My Files program and i recovered about 85% of the files lost. I still dont understand why the Folder name was changed and all the files were lost :S
