Anyone else having the problem that the s7 edge wont format or add apps to the mirco sd card. When i format sd card it just stay in formating for a long time ? i have tried different sd cards an same results ??
Honestly, that rarely happens. You could have a bad card. Try another card or reformat the card first on a computer using a reader, then insert in your S7 and try reformatting again.
