codexpennex
I've been using this 64 gb SD card for a while now and I've never been able to save music on it. Everything else saves well on it. Whatever documents or apps I save on it works fine.
For some reason, however, whenever I transfer music to the card either through ES File Explorer or via USB from my computer, it shows that its in there but when I go check it in the folder afterwards, its nowhere to be found.
I've checked online for solutions and saw one that said I should find and delete the ".nomedia" file but I couldn't find it in the card.
Does anyone have any idea what the problem is? I would really appreciate it.
I use a Samsung Galaxy S4 Active, by the way. AT&T I537.
