Try it in a PC with a card reader, if it doesn't show up there it's toast.
SD card failures are common, especially off-brand ones. Going forward, use only name-brand cards (make sure they aren't counterfeit, best way is to buy from a store not online), back up your data regularly and keep a spare card on hand.
SD cards, like all flash memory, have a life span. It's measured in write cycles - so the more data gets written to it, the faster it dies. We're talking about hundreds of thousands of write cycles, though... so it would take years to wear it out. You're talking about a 4-year old card, though, so it could just be dying of natural (well, digital) causes. I have always recommended regular backups to a PC, and then backing THAT up to the cloud. You can't have your stuff in too many places: but if it's in just one, it's a matter of time before it's gone. You can TRY some data recovery software, but expect the worst and hope for the best. Good luck
