Hey Guys! I'm new here, So I dunno if im doing this right, pleas tell me if im not!~ Anyway, My Xperia GO is getting Kinda annoying now. I find that things get deleted off of my 32gb Samsung micro SD card after transferring stuff. For instance I copy a 4gb 12 episode series folder into my micro sd card through the mini usb cable and I check my phone and the folder is empty?! It gets really annoying as it takes a while for things to copy across. I know there is no problems with my micro sd card as it works perfectly on the computer. Also Androzip lists the SD card as 3.98GB? but the phone settings and my computer also list it as 32gb? Could be an app mistake but i dunno~ If you can help then please do
Also, Anyone planning on getting the Xperia Z1f that is being released in Japan? Hopefully it becomes an international item! 5inch Xperia Z1 is just too big, So the iphone 5 sized Z1f is perfect imo. Plus its got almost the exact same specs~!!
