So I just learned that even if I put an SD card on my RAZRi, I wont be able to move the Apps to the SD card.
Does it make a difference if I restore it to defaults now with the SD card inserted?
If not then what is the SD card slot for? I mean I know we can save music and photos but it seems that there isn't much use for it.
Can you guys elaborate on the use of SD cards on ICS and the RAZRi ?
thanks guys.
thanks guys.
