Lamasiafelix1234
Please recommend the best sd card I should buy for my zte zmax pro
When I first got my SD card, my phone did say a couple of times that it was 'too slow'. Despite this, everything worked perfectly (and quickly), so the speed shouldn't be the problem. If the SD card is corrupt, then I'm not sure what you can do. Try backing up the data onto your computer (if you can) and reformatting it. Hope this helps 😋Hello everyone. I just got the ZTE ZMax Pro for my birthday. I have a Lexar SD card and the phone says it's corrupt and that the SD card is too slow. I wanted to get some recommendations at to what kind of SD card. I keep reading and find myself in an impasse with either an micro Sdhc or sdhxc? Any suggestions? Which one can the phone handle?
<br>
<br> P.S
<br> Thank you in advance.
Can use a 128g mini SD card in my Z Max Pro???
