Help sd card removed unexpectedly
Just bought samsung galaxy SIII a week ago and after updating i get "sd card removed unexpectedly" all the time tried formating in phone,pc
and there is no update to do
HELP PLEASE
I also got this with my first sd card. I returned the card and hope this new card does not do it. Otherwise its a big problem.
It's probably a defective sd card. I was getting this message with my EVO 4G. Once I replaced my sd card with a new one the error stopped.
I searched the web and found this is a common problem with alot of people
not a defected memory card because I tried another one and the same problem appeared
If anyone knows the solution HELP ME PLEASE :(
Problem Solved :D
updated the same firmware using kies air and also changed the sd card with another one from the shop really I don't know which one solved the problem but I'm glad it did :)
I had the same problem with a Transcend 32 gb class 4 sd card. I replaced it with a 4gb card.. and just to make sure there are no hardware issues, I kept ejecting the card a few times. Didn't get any problems with the 4gb card. Replaced it with another Transcend 32gb class 4 from wife's phone and it works fine so far. The card I had problems with is now in my wife's phone. Haven't seen the problem so far; not sure if it was the ejecting a few times or the card switch that helped.
