SD Card Toggles / Switches? Does this exisit?
Nagrom
Android Expert
Hi Boardies.
Okay so I transfer files to my card via USB all the time, and most of the time it's stuff I want to try out like Icons, or Wallpaper. I'm getting tired of having to pull down the notification bar, go into SD Card useage options and then swapping between Drive, Sync, or charge.
Is there a set of switches, or toggles that you can put on your home screen that allows you to swap between the different card settings without doing all this notification bar crap?
Thanks
Andy.
Can you drag image files directly from your PC Web browser into Drop Box? Wallpaper, and Icons I tend to open my card as a drive, and drag the image I want from my browser (Chrome) to the relevant folder on my SD Card.
Does Bluetooth file transfer not work with your phone/desktop? I can't quite remember what I did to set it up on my XP laptop (have a [phone Bluetooth name]OBEX File Transfer icon in My Bluetooth Places, no memory of putting it there :confused: so it couldn't have been too hard), but it works fine to move files to my DInc.
