Help "Searching for GPS" Error
isaaccallan
Hello,
My P8 Lite (5.0) has a GPS issue. It is searching for GPS when I use snapchat and Google Fit, but works fine with Uber and Google Maps. Anyone had this problem / has solution?
Isaac
Are both fine and course location enabled? I'll check mine when I get home to see what's set by default. Are you running Kit Kat or Lollipop BTW? I have one of each, so I can check either.
