I've created a tasker profile using the secure settings plugin (the gps toggle in system+ actions) that turns on gps whenever maps is opened. It turns location on (if I pull down the settings, location is indeed on) and I can even see the little icon flashing that means that it's trying to locate me, however it never actually manages to find me. I know it's the tasker plugin that isn't working because if I disable tasker and just turn gps on manually, it works fine. I was wondering if anybody had any experience with this issue and could provide some advice. Also, I'm using a GS5.
Thanks
Thanks
