security system nvr question
corvairbob
is there anyone here that messes with nvr systems? i have one i got from ebay a 32 channel unit and when i got it it had 32 channels. i could never get the ting to show my ip cameras. so in messing with it i did an update thru the unit and now it is 16 channels.
i got it to show my ip cameras yesterday but i had to go ther the 8 ch nvr that is in use now. i have 18 cameras running and watch 12 on my dvr and 8 on the nvr.
now i got this board to show 16 of these cameras but only if the other dvr and nvr are turned on and running. i expect it to need the dvr to see then on the network but it sees all the ip cameras but will not let me use those cameras username and passwords.
how i finally got them to show the cameras was to go thru the other devices. and i will stii rung the dvr but i would like to turn off the old nvr and ust use the new one.
but now i have to get the 32 channels back that it had before i messed with the update. so maybe some here have a way to do that.
if you type in this number nbd8032ra ul v2 it take you to a website for i think is the mfg. and they have a firmware file but when i tired to install that the board said it was the wrong file. it unpacks as a bin file and even that will not go into the board. if you go to ebay you find them under that number and this number hi3536 2 or hi3536 chip2. any ideas on this sure would help out. thanks bob p.
well seem no one here messes much with nvr systems. but just for those that stop and check i did get it to work and it took hours of messing around.
i did go to the mfg site and found this nvr and they did have a firmware file and i had to download it to a thumb stick and then open the zip file and then copy all those unzipped files back to the first folder the original zip file was in. then the nvr board found the file it wanted when i went into the update section and started the process. it changed the menu and then it found my ip cameras and let me change the un and pw and they started showing.
so it is now working. thanks
