T Tinderbox (UK) Well-Known Member Mar 8, 2011 #1 I have installed a few from the market, but they all have problems with the graphics , do any work ok on the defy? I am on v2.1 - build 2.21.0 Thanks.
A ABC_Universal Newbie Mar 8, 2011 #2 Which have you tried already? Fancy widget once had a very sense like theme but had removed due to copyrights issue.
T Tinderbox (UK) Well-Known Member Mar 8, 2011 #3 Must be about 6 or so, some are look like slightly different versions, see link below. https://market.android.com/details?id=factory.widgets.SenseClock&feature=search_result ABC_Universal said: Which have you tried already? Fancy widget once had a very sense like theme but had removed due to copyrights issue. Click to expand...
X Xx Tecca xX Lurker Mar 13, 2011 #4 beautiful widgets is almost exactly the same thing. infact, i bet you wont be able to tell a difference
