DrSquirrel
Is it possible to set different settings (Static with variable IPs, DHCP) per wireless profile?
ie.
Home - I want DHCP since the router gives out the IP address / gateway.
Work - I want a static IP because the router doesn't give out an address.
Currently it seems like I can only set 1 Static IP overall *or* DHCP.
/EDIT
I've found the application Wifi Static, which will automatically set based on network, before I thought it was a manual switch widget or something (and wasn't sure about DHCP).
Something like this as part of the OS would make more sense though, imo
ie.
/EDIT
