SetCPU on droid eris
Hey guys, I got my Eris a few months ago, but i just rooted it this morning. The root took and i downloaded setCPU to overclock it. however, after reading a lot of posts on these forums 710 seems to be a good number to hit and my eris sliders wont go past 528. I'm new to overclocking and rooting in general, so be gentle. :P
What rom are you running? Also could have something to do with the kernel you've got.
I just ran a apk called Eris Rooter, and it booted a file called "rootme.zip" it seemed easy enough and for a first-timer i was afraid that i was gonna brick it so something easy was welcome.
with jwmacdon's help, i was able to just root with EvilEris. the problem was the ROM i was using was setting the max CPU at 520ish. EvilEris allows it to go to 760ish.
