Hi!
I have just stated to look at Android app devoloping, and I try to learn eclipse and java programming. Mostly I have been watching tutorials and such and I haven't got that far, but i felt I wanted to try to make a small program.
I want the program to print one letter, after 0,5 s print another letter etc. I am using a TextView for this. The problem is that I get an error when I run the program in the emulator: "Unfortunately, 'name of app' has stopped".
Here is the code:
The name of the TextView is tLogo. The variable "Letter" is just a string array that I filled with the letters. The error does not appear directly but after like 0,5 s, so propably after the first loop. If i remove the line "tLogo.setText(Letter[Timer]);" I do not get the error, so even I figured out that the error is within this line.
Probably it is just a basic error, but I have tried for many hours to figure it out, but failed. It would be very nice if someone could help me with this.
If you need more information feel free to ask!
Thanks in advance!
Here is the code:
Code:
tLogo = (TextView) findViewById(R.id.tLogo);
Thread SplashTimer = new Thread(){
public void run(){
try{
for (int Timer = 0; Timer < 10; Timer++){
sleep(500);
catch (InterruptedException e) {
e.printStackTrace();
SplashTimer.start();
If you need more information feel free to ask!Thanks in advance!
