jaydee77ca
This has annoyed me to no end. Acknowledging event invitations from Google calendar emails doesn't seem to work.
I get an email for an event and touch the "Yes" in the "Going?" section. Then it launches S Planner and shows the event, and shows "Yes" under "Attending?" but below that it shows my name under "No response" and only the Organizer as "Yes".
To accept the invite I basically have to:
This is very annoying. It seems I should just be able to touch on the "Yes" in the email and have it put in my calendar with me attending.
Does anyone else have this problem? How can I fix it?
- Change the "Attending?" value to "No"
- Note the date of the event
- Go back out of the event to the calendar
- Find the day of the event
- Select the event
- Change the "Attending?" value to "Yes"
