anandkgowda
Hi..
should any one knows how to control screen brightness through program for android device. ..i did one application but it works only for that window of a android device..i need control of brightness for the whole system not for single window..i posted my code here..please do the needful..please post full code..
package com.anand.brightness;
import android.app.Activity;
import android.os.Bundle;
import android.preference.PreferenceManager;
import android.view.View;
import android.view.WindowManager;
import android.view.animation.Animation;
import android.view.animation.AnimationUtils;
import android.widget.Button;
import android.widget.SeekBar;
public class brightness_control extends Activity {
private static final String BRIGHTNESS_PREFERENCE_KEY = "brightness";
private View brightnessPanel;
private SeekBar brightnessControl;
private int brightness = 50;
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
brightnessPanel = findViewById(R.id.panel);
brightnessControl = (SeekBar) findViewById(R.id.seek);
Button btn = (Button) findViewById(R.id.Button01);
btn.setOnClickListener(new View.OnClickListener() {
@Override
public void onClick(View v) {
showBrightnessPanel();
brightnessControl
.setOnSeekBarChangeListener(new SeekBar.OnSeekBarChangeListener() {
public void onProgressChanged(SeekBar seekBar,
int progress, boolean fromUser) {
setBrightness(progress);
public void onStartTrackingTouch(SeekBar seekBar) {
public void onStopTrackingTouch(SeekBar seekBar) {
hideBrightnessPanel();
private void showBrightnessPanel() {
Animation animation = AnimationUtils.loadAnimation(this,
android.R.anim.slide_in_left);
brightnessControl.setProgress(this.brightness);
brightnessPanel.setVisibility(View.VISIBLE);
brightnessPanel.startAnimation(animation);
private void setBrightness(int value) {
if (value < 10) {
value = 10;
} else if (value > 100) {
value = 100;
brightness = value;
WindowManager.LayoutParams lp = getWindow().getAttributes();
lp.screenBrightness = (float) value / 100;
lp.flags |= WindowManager.LayoutParams.FLAG_KEEP_SCREEN_ON;
getWindow().setAttributes(lp);
private void hideBrightnessPanel() {
Animation animation = AnimationUtils.loadAnimation(brightness_control.this,
android.R.anim.slide_out_right);
brightnessPanel.setVisibility(View.GONE);
PreferenceManager.getDefaultSharedPreferences(this).edit().putInt(
BRIGHTNESS_PREFERENCE_KEY, brightnessControl.getProgress())
.commit();
xml code:
@Override
@Override
brightnessControl
if (value < 10) {
value = 10;
value = 100;
brightness = value;
.commit();
xml code:
xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android rientation="vertical" android:layout_width="fill_parent"
android:layout_height="fill_parent" android:background="#3399CC">
<Button android:text="Show Brightness Panel" android:id="@+id/Button01"
android:layout_width="wrap_content" android:layout_height="wrap_content"></Button>
<LinearLayout android:id="@+id/panel" android rientation="vertical"
android:layout_width="fill_parent" android:layout_height="wrap_content"
android:layout_alignParentBottom="true" android addingTop="10dip"
addingTop="10dip"
 addingTop="10dip"
addingTop="10dip"
android addingBottom="30dip" android
addingBottom="30dip" android addingLeft="20dip"
addingLeft="20dip"
addingLeft="20dip"
android addingRight="20dip" android:gravity="center_horizontal"
android:visibility="gone">
<TextView android:text="Brightness Level"
android:gravity="center" android:textAppearance="?android:attr/textAppearanceLarge" />
<SeekBar android:id="@+id/seek" android:layout_width="fill_parent"
android:layout_height="wrap_content" android:max="100"
android rogress="100" />
rogress="100" />
 rogress="100" />
rogress="100" />
</LinearLayout>
LinearLayout>
