Apps Setting JAVA_HOME at Android SDK
eyalm_nm
Hi, I have some conflicts with the JAVA_HOME configuration When I using the following code -
System.out.println(System.getenv("JAVA_HOME"));
I get - C:\jdk1.6.0_23 which is the correct place. But, When I run Ant command on an Android build.xml, i got the following error message -
C:\android-sdk-windows\tools\ant\main_rules.xml:361: Unable to find a javac compiler; com.sun.tools.javac.Main is not on the classpath. Perhaps JAVA_HOME does not point to the JDK. It is currently set to "C:\jdk1.6.0_23\jre"
How it can be resolved? Thanks, Eyal
