I live in a poor cell reception area and have has an AT&T Mini Cell Tower for some time.
It was very slow on images with text with my Galaxy S5, but otherwise OK.
That phone developed issues so I bought a brand new sealed in box S5, and swapped my SIM Card and used Smart Switch to move most all of my data (though some apps had to be reloaded on my new phone).
The new phone is OK with text won't send images via text (the process arrow just keeps circling forever), so I decided to activate "WiFi Calling," but when I followed the instructions, my NEW phone did not offer that option.
This is what I did to TRY to access it:
1) Tap Phone Symbol.
2) In Phone Menu (3 vertical dots), I tapped SETTINGS
3) In Settings I selected CALL
4) At the very bottom of that menu there is SUPPOSED TO BE and Option to Select "WiFi Calling,"
BUT IT IS NOT THERE.
The last item in that menu on my NEW S5 is "Vibrate"
I put the SIM card in my older S5 to see if it had "WiFi Calling" in that menu and it DID. And further it ALLOWED me to go to WiFi Calling (Choice was right after :vibrate" in the "Call Menu" as it is supposed to be), which I then activated.
I reinstalled the SIM Card in my NEW S5 thinking maybe the ATT system would alter my phone system, but no dice, STILL no WiFi Calling shown on my NEW S5.
Is there some way that my NEW Phone can be set to incorporate WiFi Calling? The phones are identical otherwise as far as I can tell except for the Icon shape on my screen. On my OLD phone, the Icons have rounded corners, and on the NEW Phone, they have square corners.
My OLD Phone w/ WiFi Calling sends Images with text OK using my Mini Cell Tower (slow, but OK), but the NEW Phone won't.
The NEW phone sends Texts with Images fine when connected directly to an ATT&T signal when away from my dead-spot home property.
Ideas?
Thanks,
Bob
Ideas?
Thanks,
Bob
