Help Settings>Accounts and sync>Phone reboots !!?
SeasideC
Hi I have a rooted Orange SanFran V 1, and recently it has started to reboot itself every time I try to enter Settings>accounts and sync. I have unrooted it and reset it to factory settings. It works for a while and then goes back to the problem. This last time it was OK until I installed Dropbox and Facebook apps. I will try uninstalling them and see if it helps, but has anyone else had a problem like this, or got any ideas ?? Thanks Clive.
