Settings Help Needed For LG Thrill On Straight Talk
jacumja
I bought a new LG Thrill for my brother to use on straight talk. I've set up mainly Iphones on Straight Talk but no Androids. Needless to say its a bit different. I had guessed I'd only need to change the Apn's but apparently more is needed. Would someone running a high end android phone preferably a Thrill please be so kind as to post their full settings so I can match them up and get this sorted out. Yes I've searched, yes I've tried the settings posted and yes its still not right.
Thanks in Advance.
Go into Network Settings->Access Point Names->[select menu button will bring up option to enter new APN]
Settings:
APN: att.mvno
Proxy: proxy.mvno.tracfone.com
Port: 80
MMSC: http://mmsc.cingular.com
MMS proxy: 66.209.11.33
MMS Port: 80
Save and select and you should be good.
