CaptSunset
I picked up an RCA tablet with keyboard/case for cheap so I could learn Android before commiting to a higher-end tablet or phablet. It runs KITKAT 4.4 on a quad core and so far the battery hasn't ballooned and I've figured most stuff out, but RCA directions are useless in several languages, and it is so low end that it isn't listed on anybody's Android forum...
So, my Qs:
1. Can i create battery problems by using the tablet while it is recharging?
2. Same Q for using a battery booster (I have a PNY T7800), & are bosters OK to use frequently?
3. The physical keyboard hogs the mini-USB port; is there a mini-USB hub to backfeed power while using the keyboard?
4. The "Office" program that came bundled has real problem- while you can usethe onscreen keyboard to type a doc, the keyboard disappears when you try to title your Save As and nothing seems to bring it back. Is there a way to lock the keyboard ON?
5. RCA gives out no specs onthe CPU or how to remove the bundled flotsam, can anyone recommend a free Android guide that is mid-level comprehensive?
Thanks in advance (this took 30 minutes to type, btw!:])
So, my Qs:
