Ford Sarnmenington
Hello:
I have a Galaxy S3 that I've been very pleased with until recently. For the past couple of months, the battery wouldn't seem to hold a charge. I figured the 2-year old ZeroLemon battery I had installed was at the end of its life-span, so I bought another ZeroLemon battery as a replacement. Now, once the battery has been on the charger overnight, it reaches 100% and if I immediately unplug it and let it just sit (in Power Saving mode, no less) after a mere 2 hours or so of literally just sitting there, once I pick it up again the battery life reads from 70% to as low as 55%. I immediately check the battery use indicator in "Settings" and it tells me that 39% of battery usage is from "Android System" and 30% of usage is from "Android OS" when all it's been doing is sitting there idle and draining away half its power. This just started happening a couple months ago and it's driving me crazy! Could it be a hardware issue? An update I'm not aware of? Please help!
