Hi guys,
I posted a long tread where I was frustrated because after some rooting and unsuccesful/sloppy rooting and install of lagfixes it started vibrating a lot and some applications went "force close"
I downloaded a lot of unnecessary apps because I was confused instead of just sticking with one method.
I after a post on this and another forum for help, decided to do the three button start-up ( I am sure there is a more fancy name for this feature) and encountered a massive amount of options, amongst them factory reset.
I did a factory reset; all my files (films music etc is still there), only apps and contacts affected. which was great and the phone is still super fast, like it was when I successfully installed voodoo a week ago with odin.
Now the settings "about phone" tells me this:
Kernel version: 2.6.32.9
curio@carton # voodoo_stable_5.5
Q1. Is the phone still rooted now after the factory reset through 3 button start up?
Q2. Is the warrantee affected at this point?
Q3. If so, what could I do to make it appear completely "normal" again? Is it even possible?
Q4: It seems like the voodo lag fix is still on. Is that right?
See, I am considering to switch to optimus 2X, for excitement
. I bought the phone this mid-February and it looks absolutely new. I have used silicon skin and a screen protector. has no scratches etc. Except for the problems encountered mentioned, it has been working fine, and I am happy with it (ecspecially now with the lag fix! It is very fast.) Just seems that the 2X seems a little better.
If someone is interested in the phone, please tell me. It is bought in Norway, so if you
