I have a rooted, MIUI(ICS) SGS1.
I have only an internal 16gb sd card and it has 2 partiotions: Internal memory and external memmory. The internal memmory contains 1.87gb and the rest is in the external memmory. The problem is that i have installed apps only up to 400mb, and even used App2SD but still it says i have "Not enough space on internal memmory" to install more or sometimes even update the existing.
My file manager, Wifi file manager and the App MGR III all say that i have about 1.48gb of free space. I have toconstantly clear my cache every 4 days in order for the phone to function normally, because if i dont clear the cache or install another app every living proccess starts to die, even background proccesses you cant close through the Task killer start to crash and any app i open closes instantly.
I Have tried to create a partition(512MB) through the CWM and use the Link2SD app but instead it redused my internal memmory to 480mb and the external remained the same(i think)-14.6GB.
Dont know what to do.. Please help!:s::s:
