Should I activate previous phone temporarily?
Schmohawk
Member
I had a Huawei Ascend til early May, when I bought a used Samsung Admire. On the Ascend, I was getting decent 3G speeds but since flashing the Admire to non-stock ROMs, I've only been getting 1X, And even that is s-l-o-w. If I were to reactivate the Ascend, would it be simple and quick to reactivate back to the Admire after I find out how my data speeds are?
Thanks,
Don't I need to use the online tool on the Metro site to enter the new (old) MEID, before programming with *228?
*228 gives you the option of activating your phone as well as many other options.
MEID is specific per device:)
Your phone number could be switched to another phone but you will not be able to use the same number for both phones.
Hope this helps!
Hope this helps!
Yep that's what I meant I was just trying to reply real quick before I left the casa
Sent from my typewriter.
Hope this helps!
Yeah, I don't want to use both phones at once.I figured if I could reactivate the Ascend, and see if it's getting 3g, then I'll know the Admire has a problem; if the Ascend also only gets 1X, it would more likely be a network issue. . . maybe. ;-9 Then I'll switch right back to the Admire.
Thanks!
