The ones you sideloaded are the ones you have...if you check the zip contents and the creator didn't add in the images for the update then your going to fastboot flash them yourself or use a modded twrp to flash the img.
If you flash the full factory image as is, everything is done automatically, unless you want to flash each of them one by one, which you may have to, as some people are reporting.
