How to boost signal in a dead zone ,also the WiFi is terrible, how do I diy signal enhancer
Also, I've had fair luck with this app, gives you a lot of useful information.
https://play.google.com/store/apps/details?id=com.wifianalyzer.analyzer
You're approaching your problem of bad reception (both cellular and WiFi) from the wrong end. Your phone is on the receiving end so it's in no way a matter of some kind signal enhancer you install on your phone. The problem you need to address is why both the mobile data and WiFi reception is a problem, your phone is having issues receiving a wireless signal, it's not a matter of transmitting a signal. Also note that cellular signals are transmitted by cellular towers (either on discrete towers or mounted on top of taller buildings) with WiFi being a much, much more localized wireless signal being broadcast from a wireless router inside one's home.How to boost signal in a dead zone ,also the WiFi is terrible, how do I diy signal enhancer
