Silencing Camera 360 shutter sound
lemon2
Hi
I'm using the camera 360 app on my Galaxy S2, and even when camera shutter sound is unticked in the settings, it still makes a noise.
Does anyone know how I can silence it?
If you know you're going to use the camera, turn the volume all the way down, or use silent mode. I don't think internal option works on all phones.
I guess all phones are different. My Optimus-V has no "click" if volume is down, and the "no click" option in the app doesn't work.
The cam's autofocus can make noise.
It's usually a mechanic design, with some designs the lens has to move :)
Harry
