SIM1 is disabled after using a secrete code *#*#4636#*#* and change set preferred network type to GSM/CDMA auto (PRL) (after restarting mobile). It automatically set to a network type unknown. When I try to enable SIM1 to menu > settings > dual sim settings > configure dual card > sim 1 card it gives me error message "the process has stopped unexpectedly please try again".
I tried every thing
1)apply factory update.
2)Reset factory setting.
3)Wipe cash partition and then apply factory update.
4)Wipe data/factory reset.
Any suggestion............ Please Need Help.![Thinking :confused: :confused:](/styles/smilies/google/thinking.png)
I tried every thing
