On my HTC Eris I just use the built in alarm clock app. It has three different alarms, I use one of them for 'dumb stuff I gotta do' reminders. It's quick and easy, and has the added bonus of not requiring another app to be downloaded to the phone.
I just browsed the android marked and came acros an application I think suits all my needs. It's called "RemindMe" which does everything I need and nothing more.
Hi, you can try an app named GMnote,which is really a simple and easy-to-use app. Its only function is to write down notes and set alarm to remind you. It is worth your try.
