Simple way to grab promotional offers.
Cade12
Well, I hope this helps others - like it did me.
So, we all know it's not as "easy" as visiting Verizon's website (or going to a store) to find the details on promotions. It's an endless loop of adding this to your cart or sifting through fine print to get the details. Also, sometimes they have better deals in-store vs. online. I'm frugal and want the biggest bang for my buck.
Spent time online and found a simple blog (VZ Guru). It basically spells out Verizon's promotions, what you have to do to qualify and shows what other promotions can be combined.
If you're trying to save a few bucks here and there - might want to pop-over and see if it helps you. Their blog is vzguru.com
