Hey guys, I'm taking a mostly minimalist approach with my phone, an LG Optimus V. I'm running LauncherPro and have cut out all of the other screens. In other words, there is no sliding or swiping to a new set of icons or widgets, and thus no slight shift in the wallpaper from doing so.
I still would like to personalize with a static wallpaper. I'd like to do this without a Wallpaper App constantly running in the background; that seems counterproductive.
Currently, when I set a wallpaper, I am required to crop a photo that is wider than it is long. I'm not sure how many screens the photo is dimensioned for by default, but it is definitely more than one since the main screen (which is longer than it is wide) crops the excess width.
I can figure out an image editing program if LauncherPro has no easier way to do this. I was hoping I just missed some setting for wallpapers to be sized equal to the current number of screens, or something along those lines. If not, can I simply crop an image to the size of one screen and add whitespace/blackspace on both sides of the image so it technically fits all screens?
If so, how many screens should I account for? 3? 5? 7?
What dimensions should the isolated, unpadded wallpaper image be?
The screen specs are: 3.2 in. and 320x480 res.
And what should the dimensions be for the total wallpaper, including the whitespace?
Is it better to have higher dimensions (but equivalent ratio),
or to deres to the exact pixel count when making a wallpaper.
Any input on this would be great; I'm a bit OCD, and the lack of control of what is shown in my wallpaper exactly is killing me.
I have know idea why this would be - I never heard that problem from others with different phones with the same resolution. So as I said, It should work, but I'm not sure it will. If it does come up, a wallpaper app such as "Wallpaper set and save" or "Wallpaper wizardrii" may help.
