So I'm a little confused about Skype on Android.
As I understand it, it's not really running Skype at all, it's just a fancy way to call their local Skype number, which you can actually do on any cell phone, right? So you still use minutes. If you make long-distance calls, you'll also use credits. If you make local-calls, I assume you don't? And do you use credit if you make Skype-to-Skype calls? What if someone Skypes you -- do you still use credit?
Second, can Fring really do real voip Skype calls? Just using my wifi and no minutes? Can I see all my Skype contacts? Can they see me?
If someone tries to Skype me, can I pick up using Fring?
Should I bascially just use Fring, because it actually does what you would expect Skype to do?
(I've never really used Fring before, so don't really know much about it)
