Slacker Radio stops playing after screen lock
burnsiv
I know other Hero users are having the same problem, and so far Slacker support has not fixed. One the screen sleeps it will finish the current song but not play a next song until you unlock the screen. I even have an app that keeps the screen from locking but allows it to go black and that causes the same issue. Anyone have a suggestion? This makes it where I can only use Slacker with the screen on which make the app almost worthless.
I think you've answered your own question. It is a problem with the Slacker app, and if you don't want you screen permanantly on, then there is nothing you can do. I suggest contacting the developer of the app as this has nothign to do with the hardware.
