I'm using TestTube to watch my Hava and have the same lag between video and audio. The dev says it is the way Android handles media and he would have to patch the OS for it to sync. It sounds like the sling player is having the same problems. I think you just saved me $200!!!I have a Slingbox AV and it does work but I am getting a lag between audio and video. Has anyone else had this issue? I am wondering if the problem is I am using the older AV model and I wonder if I got a solo if it would work better?
Does anyone have the SingBox HD? Can you get HD quality over 3G? My SD content looks pretty good.
--HTC Evo
The solo doesn't have any kinf of tuner, you would have to hook it to a cable box, vcr, etc. The Pro-HD "Includes built-in analog and HD digital Clear QAM cable tuner and ATSC antenna tuner" in addition to hooking up to any other kind of tuner. Here is the link to the various products: Sling Media - HardwareCan you hook up the Slingbox directly to your cable or must it go through a cable box? I guess if it doesn't have a tuner you could always hook it up to an old VCR or something?
Well, the HD is $260, so will have to take the plunge on that one
I was hoping that the VULKANO be out there, but the website for monsoon multimedia originally stated that it would be ready for April, then May, and now it says summer 2010
Baloney, I am not waiting for them anymore
what's the fuss about this? it's damn expensive.
Take a look at the testtube group in google groups. It has a lot of information on configuration. I've been running it on my droid since the first day it came out. I have the platinum. There is a download on the myhava.com site to update the gold to work with the newest pc app, maybe that would help too. I get the Video cannot be played once in a while, I just start it again and it works. Good luck!I have a Hava, GOLD though, I downloaded the TestTube application, but no dice, it doesn't work with my Droid, it only tells me that the Video Cannot be played
Oh well
Is anyone using the sling box classic? Do I really have to buy a new sling box?
