Hi
My Tab 4 runs slowly. The apps seem to need constant updating even though auto update is on.
Is there a way to boost the wifi capability of the machine?
Or boost its speed.
It is practically brand new. Tons of memory left etc.
Thanks
B
Hi
Or boost its speed.
Thanks
B
The Tab 4 7.0 was released in May of 2014 so as a model it's not new. Did you buy it new (as an inventory clean up) or is it 'new' as in you bought it used (but 'new' to you). If it is a refurbished unit that might indicate a Factory Reset wasn't done to it. In that instance you should back up any of your personal data, and do a Factory Reset to see if that makes any improvement.
You might also want to boot it into its Recovery Mode and wipe the system cache partition.
As for '...apps seem to need constant updating...' is it a matter where the same app or apps require updating each day, or is it just an issue where you see a message every day that one or more of your apps have been updated? If the former that does indicate there's a problem, if the latter that's just a typical occurrence as it's not like everything gets updated every so often all at once. App updates become available as each developer/company releases them so one day you might see several, and then for several days maybe just a few or none.
